Minor glitch
All  1  2-4
5331.2 In reply to 5331.1
Hi eric, is it possible that the script for Alt+A is not set up anymore in your keyboard shortcuts?
Double check under Options > Shortcut keys, if it's not there then set it up from here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3918.2
If that's not the issue then can you please send the file to me at moi@moi3d.com so I can test with it over here?
5331.3 In reply to 5331.1
Hi eric, thanks for sending me the file to test with - as I replied in e-mail, it turned out to be a bug in the sorting script where it would actually sort styles into 2 different sections depending on whether the style name started with an upper-case letter or a lower-case letter. It seems like there's always something tricky going on with programming... ;)
I've updated the original post with a new script (same one I sent to you through e-mail) so that it should not do that anymore and it should now work properly.
Thanks, - Michael
5331.4 In reply to 5331.3
Thanks Michael ...
Wow! What a remarkably fast answer. Works perfectly!
cheers
eric
Show messages: All  1  2-4
