Need Help with UI - Scene/Object Browser
All  1-2  3-6
5319.3 In reply to 5319.2
Thanks Michael.
I'll look forward to your future enhancements there. I will say, from all my experience with other "squishy" UI systems, whatever risk of accidental shifting which might occur, is vastly outweighed by the value of being able to quickly re-size whatever you want on the fly.
5319.4 In reply to 5319.3
Strange. I just tracked down the "BrowserPane.htm" file, but when I open it with TextEdit, it's totally blank.
Thoughts?
5319.5 In reply to 5319.4
Hi sneather, I also noticed that TextEdit.app does not like to edit it for some reason, I had to use XCode to do it instead which worked fine.
Maybe try copying it to some other directory first, maybe TextEdit won't edit things inside of a application package of something like that.
Also I've attached here a version that has the width doubled so you can copy this file over to of the existing one.
5319.6 In reply to 5319.5
Sweet! Thanks. I don't have MS Word on the machine with MoI, otherwise I would have tried that, too.
I'll use your replacement for now.
Thanks again!
Show messages: All  1-2  3-6
