Weird Glitch
5315.1
Hi everyone,
As I move my mouse around what is visible changes drastically, occasionally the colors will invert, it makes navigation and work impossible. See the attachment. This is happening for every file I open, even new ones.
5315.2 In reply to 5315.1
Hi yakas, in the current beta there has been some changes to use multiple CPU cores to help speed up the display, maybe you're running into some problem related to that.
You can disable it by a setting in moi.ini - to do that go to Options > General and push the "Edit .ini file" button. Then inside there find the [View] section and inside there find the DisplayThreadLimit= setting and set it to say:
DisplayThreadLimit=1
Does that make any difference?
Also what kind of video card do you have in your machine?
5315.3 In reply to 5315.1
Hi yakas, also I'd better verify which MoI version you are seeing the problem in - is it only in the latest v3 beta and does the v2 release behave normally instead?
5315.4 In reply to 5315.3
Hi Micheal, I won't be able to adjust the .ini until next week, but it was happening in the current and previous beta release, I actually do not have v2 installed on that computer, but I will try it out. The computer is a lenovo all in one i3 with an intel Graphics Controller Model: HD 2000.
5315.5 In reply to 5315.4
Hi yakas, if it was happening in the beta release before the Jul-20-2012 version, then it doesn't have anything to do with the multi-core changes since that was new for the Jul-20 version.
It's probably a good idea to see if there are any newer drivers available for your video card, maybe try going directly to the Intel drivers site and see if you can get a new driver from there.
5315.6 In reply to 5315.5
I'll check it out, thanks.
5315.7 In reply to 5315.6
driver update fixed it, thanks
