Components?
 1-14  15-29
5313.15
Being able to select a whole group in the viewport would be nice.
You click on the group and it selects all the objects.
Xara has some practical examples of object organization, several kind are possible:
Groups: Cluster of objects like described above, possibility of nested groups.
Soft Groups: Stacking Objects can be spanned across several layers and reorganized afterward, does not change stacking order.
Named objects: Object or group of objects can be named and they can belong to several different names tags, making cross-association possible. An example here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=2127.47
Live copies: Instancing.
There's also Clipview but that wouldn't apply much to 3d.
Ctrl+Clicking on a group will select an object inside a group, Ctrl+alt+Clicking will select nested groups inside, repeating will cycle through them...
Marc
5313.16 In reply to 5313.14
Vectorworks uses a system of Groups, Symbols, Classes and Layers, which is very powerful.
Groups act as 'boxes', organising the drawing into discrete sections. A duplicate group is independent from the original. Groups aren't named, they're simply a drawing tool that allows disparate objects to be linked for convenience.
Symbols are clones - similar to a SU component. Change any symbol and it updates across the file. Useful for repetitive elements (obviously), such as standard size doors, they're named and organised in a library (which can be referenced from an external file). Symbols can be automatically inserted into walls in the manner of SU, but this is complex and not that important in practice - it's the ease of updating that's particularly useful.
Classes are the equivalent of Moi names. Classes can set global properties - colours, lineweights, opacity, visibility and so on. Classes operate drawing-wide, affecting members of groups and elements. Useful for grouping materials.
Layers are the equivalent of separate drawing sheets overlaid (storeys of a building for example). They can probably be discounted here.
The system works well, and would certainly help me in my use of Moi - I find it too easy to change something by accident..
In your futur system of Instance
like in SKetchup if you modify any copy of a component all same components will be modified ?
And a possibility to make an instance of component "Unic" ?
5313.18 In reply to 5313.17
Yup, that would definitely be part of it.
Sorry I'm not sure what this part means.
Unique?
5313.20 In reply to 5313.19
So "different" - not "genderless". ;-0
Yes! Unique :)
5313.22 In reply to 5313.21
Hi Pilou, unique in what way in particular?
In general instancing mechanisms are focused on making large amounts of duplicated objects, and duplication is pretty much the opposite from unique.
5313.23 In reply to 5313.22
It's just for isolate a component from a familly of instanciation
5313.24 In reply to 5313.23
Hi Pilou - yes there would also be some mechanism in place for changing an instance into a regular non-instanced full copy of the object so that you could then use it as a regular object after that.
5313.25
This will be killer!
5313.26 In reply to 5313.24
Actually, at least in SketchUp, given a component (call it "Comp1.00") - or any of its instances (Comp1.01, Comp1.02, etc.) - when selecting any one of these and making it "Unique" one turns it into a new component (call it "Comp1.02_Copy1.00"). This is like a branching out from the originals a new non-twin sibling whilst still allowing new instances from that new copy. In other words, both the original and the unique copy remain "instance-able".
Cheers,
. Diego .
5313.27
I want to vote this one up on to the priority list :-)
5313.28 In reply to 5313.1
I want to vote this feature up!
5313.29 In reply to 5313.4
A hierarchy can be established through components in conjunction with a components management tool.
Show messages:  1-14  15-29
