2d blend and trim
All  1-5  6-7
5304.6 In reply to 5304.4
Hi Marc, re: Eraser function, are you talking there about something that's just totally driven by mouse movements alone (like cutting things by a roving circle around the mouse basically), or do you mean something that would use other current geometry in the model as the cutters?
5304.7 In reply to 5304.6
It could work in two modes:
1 : Like some kind of quicktrim where everything under the drag would be cut to the nearest crossing curve.
2 : Like a big lazy eraser using no existing geometry, wiggle and trim in one click.
Both could use a round adjustable radius, like a kind of paintbrush.
An example of the fist behavior, one could swipe through (in red):
And get this result
There could also be an alternate selection mode using this method, sort of paint to select.
It would be quite quick for complex multiple line or point selection...
Just thoughts.
Marc
Show messages: All  1-5  6-7
