SketchUp back to MoI
All  1  2-14
5286.2 In reply to 5286.1
Save as OBJ inside Sketchup
By this free plugin by TIG Export OBJ
http://forums.sketchucation.com/viewtopic.php?t=33448
then use this cool prog by Michael ;)
OBJ to 3dm (Don't use huge size like ZBrush OBJ file ;)
http://moi3d.com/download/Obj23dmWireframe.zip
EDITED: 27 Jul 2012 by PILOU
5286.3 In reply to 5286.2
Great - thanking you!!
5286.4 In reply to 5286.2
Oops I'm on a mac. Any osx friendly obj converters?
5286.5 In reply to 5286.2
I have the WIP Rhino for OSX, but when I save out a 3dm from there MoI wont open the file...
5286.6 In reply to 5286.4
SUp Iges exporter http://forums.sketchucation.com/viewtopic.php?f=323&t=43307
Is not a magic bullet and also you will need to import the .iges with RhinoOSX fist then save and open with MoI. (for some reason MoI does not play well with that SUp Iges exporter).
5286.7 In reply to 5286.5
Rhino reads Nurbs & Polygons, MoI reads only Nurbs...
5286.8 In reply to 5286.4
Hi Rich,
you could try WinOnX, which is very cheap and i use it with Michael's converter too.
http://itunes.apple.com/de/app/winonx/id421346233?mt=12
5286.9 In reply to 5286.4
<< Oops I'm on a mac. Any osx friendly obj converters?
Sketchup don't work on a MAC ? OBJ is not supported?
5286.10 In reply to 5286.8
WOW Thanks for posting that Stefan, does it really work?
5286.11 In reply to 5286.10
Hi adamio,
yes it works, mostly with not so complex Windows programs, like Michael's nice .obj converter.
5286.12 In reply to 5286.11
thanks Stefan, Just got my copy :)
5286.13 In reply to 5286.5
Hi Rich,
That's because Rhino has stored a polygon mesh object in the 3DM file, while MoI only reads NURBS objects from 3DM files.
There are all kinds of various different things that Rhino can put in 3DM files like spotlights, dimensions, mesh objects, annotation dots, etc... MoI does not deal with all of that other stuff, it's only set up to work with NURBS objects.
That's kind of the fundamental problem - your SKP file has its data as polygon meshes - that is a much different way to structure 3D model data than the way MoI structures it. Polygon mesh data does not have any actual curved surfaces in it, instead curved surfaces are approximated by a lot of little flat triangular facets. MoI is not set up to work with that kind of faceted data, instead the NURBS surfaces that MoI is designed to use are spline surfaces that are actual smooth entities.
It is possible for MoI to export to a polygon mesh by taking the large smooth NURBS surfaces and dicing them up into little pieces. But it's not so easy to go the reverse way and start with already diced up pieces and try to reform large surface sheets from that.
It's sort of like how if you start with apples you can get applesauce by smashing the apples up. But if you start with applesauce it is not so easy to reform apples from that.
So because of that, typically the process of moving data from MoI to Sketchup is a one way street, where you can export data you create in MoI into the SKP polygon mesh format (with sufaces getting diced up into facets) which SketchUp can open, but not go the reverse way at least not easily.
If your SKP file is primarily made up of larger planar surfaces and not a bunch of triangulated ones that are trying to emulate curved surfaces, there is an option in Windows Rhino I think for opening the SKP and converting things into trimmed planar NURBS surfaces, that type of conversion would then come into MoI. I'm not sure if the Mac Rhino version has that yet though.
5286.14 In reply to 5286.13
Ah of course - thanks for the run down Michael. The applesauce metaphor was a nice touch - I will have trial with my Win. Rhino for export...
- Rich
Show messages: All  1  2-14
