Projecting splines
All  1-7  8-13
5268.8 In reply to 5268.7
A million thanks guys you've given me food for thought about the best ways to get this done.
Lang
5268.9 In reply to 5268.8
Michael I just done exactly what you said and and but also cleaned up the lines as like you said bemfarmer some of the lines don't match up properly (strange as this cutter file was supplied). Anyway thanks again guys as this will save a lot of time.
Lang
5268.10 In reply to 5268.9
Hi again guys
I've been playing around with this carton and cutter and have just come across this little problem. I've unified the central hub of the box so I can fillet the edges but when I do this it seems to be making some sort of elongated fillet along the whole of the plane and more. As I've booled/unified it and there aren't any curves I can't rebuild it just in case this is what I should've done?
Lang
Size: 652 KB, Downloaded: 37 times, Dimensions: 1723x837px
5268.11 In reply to 5268.10
Hi Lang - re: fillet - because your central hub piece is not a closed solid and is an open surface with the ends actually being different lengths:
That kind of situation is making it difficult for the filleter to figure out how it should trim off the ends of the fillet surface that is constructed. So instead of any trimming you just get the full extended fillet surface.
If you wanted the fillet to be automatically trimmed, you could try to make the box to be a fully closed solid instead of just some open surfaces, that will help it to know how to cut the fillet with some of the side wall surfaces.
But probably the easiest thing to do is to just trim the fillet that was generated to whatever you need - the just newly released V3 beta actually as a Trim by Isocurve option which is handy for just this type of situation. To use it, use Edit > Separate on your fillet to break it out so that it's just a single surface all by itself and not joined to anything else. Then select it and run Edit > Trim , then push the Isocurve button and you will then be able to pick a point on the surface and you will see some lines across the surface to use as cutters, switch the direction to U or V to get the particular cutter line that you need. I'm not exactly sure how you want the result to be formed since the ends are not aligned, that's up to you to decide where to place the cut.
So basically the fillet that you see there has generated the raw extended material that you need and you can then trim it to cut it down to be smaller.
5268.12 In reply to 5268.10
Hi Lang, also this part of your question here:
There isn't anything actually wrong with what you have done so far - if you want the fillet to be automatically made to be smaller you could do that by building a solid first with capped ends and then filleting that. But it's not like there is anything particularly wrong with the fillet you are showing there, if it's too big for what you want then you can just cut it using Trim...
5268.13 In reply to 5268.12
Thanks Michael, much appreciated as ever.
Lang
Show messages: All  1-7  8-13
