new beta soon?
 1-6  7-26  27-46  47-66  67-86  …  107-119
The display is a great strategic place to get some benefit from multi-core processing too, since it's something that gets heavy continuous use.
5252.28
This is great news Michael, you always have something to offer that excites MoI and CAD users alike.
Maybe a marketing stratagy along the lines of 'MoI now with Quick Draw' :)
Quick Draw
5252.29 In reply to 5252.25
""""""""""Well, both shaded surface drawing as well as curve/edge drawing get boosted, but surface drawing was not as CPU intensive so it's more down in the 2x range, edge/curve drawing is more towards the 3x range."""""""
Ah yes, Thanks. I really only ever had an issue when I had a bazillion little "edge" pieces to deal with. This should be great.
@Danny. Shleb and mildred in the draw contest too? :) (Aussies will take the first beta download again? 10 paces brother.......:)
5252.31 In reply to 5252.26
> > It's mostly tested with some of the more complex models that you've sent me... This should help make it easier to not have to turn edges and hidden-line edges off quite as much as before.
Hehe that's great, glad it helps ! (do you want some others ones ?)
but wondering ... if you give me 4*times more speed, I'll push MoI even further ... so this time the limit would be probably the memory ?
I have a spaceship model here that is still 'manageable' (I mean I can turn around with a usable framerate), but MoI is allready using 750Mb of memory ... well that's what windows task manager is reporting, not sure if it's really accurate. Looks like it would be easy to break the 3gb limit from the 32bits MoI version ?
In other words, we need a 64bits version of MoI sir !!! :)
(I have build a new computer last month, and I was amazed that 32gb of ram was cheaper than the motherboard ... )
Anyway, I cant wait to test it ! ... and spread the news :)
EDITED: 18 Jul 2012 by PAQ
5252.32 In reply to 5252.31
Hi PaQ, yeah as various pieces speed up probably memory consumption will be a bigger barrier for you. MoI as a 32-bit program can get up to around 4GB (well in the neighborhood - maybe more like 3.6GB) on a 64-bit OS though, not just 3GB... Also I think that probably implementing an instancing mechanism may actually help out more than 64-bit-ness for a lot of cases.
I certainly understand that you'd like a 64-bit version of MoI, but in order to do it would require a major churn in my development environment needing to switch to a new compiler and updating all support libraries and dealing with various compatibility issues from that. That's going to be very disruptive for me and so I don't think it's going to be likely to happen anytime too soon.
Some previous discussion here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5172.5
5252.33 In reply to 5252.32
""""""""I certainly understand that you'd like a 64-bit version of MoI, but in order to do it would require a major churn in my development environment needing to switch to a new compiler and updating all support libraries and dealing with various compatibility issues from that. """"""""""""""""
Was this an initial concious decision, or is it just a bi-product of starting the dev cycle before the proliferation of 64 bit?
5252.34 In reply to 5252.33
Hi Burr,
Pretty much the byproduct part...
But it also doesn't help that each new version of Visual Studio has kind of gotten worse in various ways and that's another thing that's kept me from going to new versions for a while.
5252.35 In reply to 5252.34
Thanks Michael, I understand.
5252.36 In reply to 5252.28
Hey Danny, how about Phineas J. Whoopee's 3D BB (Black Board)!
5252.37 In reply to 5252.36
Hi Michael T.
Not that familiar with Tennessee Tuxedo might of been a little before my time, plus I don't think we got all the US toons here down under.
Amazing that Don Adams did Tuxedo's voice though! I still catch an episode or two of 'Get Smart' :)
Ok, new v3 beta is out, you can get it here: http://moi3d.com/beta.htm?rev=x
It may take me a day or two to gather up more info and make the official announcement.
But briefly the new stuff is:
Multiple cpu cores used in the draw engine - should speed up the display of complex models on multi-core machines. Please let me know how it benchmarks on your system, you can get a numeric benchmark by turning on the viewport display time which will put up a number in the upper-left corner of the viewport for how long it took to render a frame. You can toggle that on and off by setting up a shortcut key with the following script on it:
script: /* Toggle redraw time display */ moi.ui.showViewportDisplayTime = !moi.ui.showViewportDisplayTime;
You can compare numbers with that turned on in the previous v3 beta or v2 to the new multi-core enabled release.
PDF import has been totally overhauled, it should be a lot more robust and some kinds of PDFs that would previously get garbled should come through ok now.
New Extrude to point and Extrude tapered options for the Extrude command (2 new buttons on the Extrude options panel).
New Isocurve command under Construct > Curve > Iso, and a new "Isoparm" option for the Trim command when trimming a single surface.
I'll try to gather up some more details and make a proper announcement within the next couple of days.
5252.39 In reply to 5252.38
Cool
We can go to the camping with the new release!
Bravo!
5252.40 In reply to 5252.38
Thanks Michael G.! Hope to check it out sometime today!
Michael T.
Nice new icons transform !
But maybe the generic Deform must be different than the Flow ?
Cool the new extrude functions :)
Perfect the iso curves!
EDITED: 20 Jul 2012 by PILOU
5252.42 In reply to 5252.41
Hi Michael!
...some benchmarks:
Inventor import via IGES with ~250 objects, older INTEL Quad. Selected all objects, reset view and did some "serious" rotating..
mesh angle 10:
MOI 2: ~193-207ms
MoI 3.0 beta Apr: ~200-216ms
MOI 3.0 beta Jul: ~99-103ms
mesh angle 5:
MOI 2: ~460 ms
MOI 3.0 beta Jul: ~216ms
BOOOM!
I did check the CPU Usage History. All 4 Cores online..
Great work,
~ Marco
5252.43
WOW PDF import has been totally overhauled INDEED that's a game changer, no more Round-trip :)
2.5
3.0
5252.44
Here is my test opening a 100Mb filesize
Windows task manager show performance when loading the file
MOI V3 20 JULY=1023 ms
MOI V3 16 APRIL=1150 ms
Intel core quad 9450-8 Gb RAM
EDITED: 25 Mar 2021 by M-DYNAMICS
5252.45 In reply to 5252.20
Thanks Michael ...
eric
5252.46 In reply to 5252.38
Thanks Michael,
Awesome.
eric
Show messages:  1-6  7-26  27-46  47-66  67-86  87-106  107-119
