Closed curve edges to edge selections
All  1-7  8-13
5250.8 In reply to 5250.7
Hi Lang,
> Michael, do you plan to add the rebuild to UI eventually?
Yup, I just haven't figured out a good place to put it yet.
5250.9 In reply to 5250.8
Michael, there's a blank spot open in the "Edit" pane. ;-)
If you make an icon group for "Tools" or "More", you could put sub-icons for Rebuild, Merge, ShrinkTrimmedSrf, and Flip.
And because it would be at the bottom right, you could have two rows at eight total features.
- yet, you would still not really notice it cluttering up the UI, because it's all hidden in a group.
5250.10 In reply to 5250.9
Hi Mike, I'm not quite sure yet whether to do something like that or whether to put a bunch of tools on to an "extended properties" dialog which will probably hold a lot of other things as well.
It seems like some lesser used and specialty tools should probably just be on some kind of text menu or text buttons rather than needing an actual regular big icon button.
I'm pretty sure that there needs to be a properties dialog with a lot of other information and controls present on it already so that might be a good location for these things as well.
5250.11 In reply to 5250.10
That'll work.
And maybe some extended list like that would scan the Commands or Scripts folders for anything third-party, so to speak.
5250.12 In reply to 5250.11
Hi Mike,
I think that will go on some kind of Plug-ins button on the bottom toolbar that will pop up a big menu of installed plug-ins.
But I also want to overhaul the plug-in installation system so that they're stored in some central location like where moi.ini is instead of needing to be copied into the commands folder.
5250.13 In reply to 5250.12
>But I also want to overhaul the plug-in installation system so that they're stored in some central location like where moi.ini is instead of needing to be copied into the >commands folder.
This would be good idea. would make it a bit easier to re-install MoI (I blew away a MoI install then realized I had forgotten to make a backup of all the extra scripts i had installed :) )
Show messages: All  1-7  8-13
