How to Resize a Multitude of Similar Objects?
1-11
12-31
32-35
Michael Gibson
12 Feb 2021 (32 of 35)
5243.32
In reply to
5243.30
> Seems RotateObjects Rotate only in the vertical direction!
> Does it possible to have the other directions ?
Can you show an example of what you're trying to do? Maybe the node editor would be a good solution.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
12 Feb 2021 (33 of 35)
5243.33
In reply to
5243.32
Say in this case for any reason i want rotate all objects just after the explodeMove following the Y axis
But seems James gives us just the answer with the Node editor! :)
https://moi3d.com/forum/index.php?webtag=MOI&msg=10159.6
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
12 Feb 2021 (34 of 35)
5243.34
In reply to
5243.33
Hi Pilou, also there is RotateObjects2 which allows you to pick the rotation axis either Top, Front, or Right views:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8558.4
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
12 Feb 2021 (35 of 35)
5243.35
In reply to
5243.34
Missed this one! Excellent!
So will be added in no time here! :)
Done: French version!
https://moiscript.weebly.com/rotateobjects.html
EDITED: 12 Feb 2021 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
12-31
32-35
