Filleting Issue
All  1-11  12-18
5239.12
The only problem I find with MoI is the lack of variable radius filleting. Michael says he is working on it, so we will have it eventually.
As for filleting success, it often depends on the underlying engine. Autodesk have developed there own having broken away from the standard ACIS kernel when Spatial were acquired by Dassault (owner of Solidworks and a Parasolid engine user).
You can get Inventor Fusion for free at the moment. Often it's filleting engine will succeed where MoI's fails particularly where edges join at acute angles.
5239.13 In reply to 5239.12
Inventor Fusion
The Microsoft Windows compatible technology preview executable expires on April 1, 2013.
The Apple OS X compatible version of the technology preview expires on January 1, 2013.
Else you can see this tutorial for complex Fillets inside Moi by MajikMike ;)
http://k4icy.50webs.com/tutorials/Fillet_Using_Sweep_and_Blend.html
5239.14 In reply to 5239.13
I use the built in Error notification/discovery supplied with MoI. If the fillet doesnt work, review the area being filleted. This same mechanism is also used in "professional" environments daily! :o
5239.15 In reply to 5239.14
Maybe if the fillet is difficult, that want to say that the form is not natural and tortured! ;)
At the French Billiard when you must make a "massé" that want to say that your previous play was not optimum ;)
Minute 4.09 - 4.18 :)
This nature of keep the 3 balls along the side of the billiard is called "The american" ;)
EDITED: 9 Jul 2012 by PILOU
5239.16 In reply to 5239.13
@Frenchy Pilou: Many thanks for the tutorial link. This is really good information...
5239.17 In reply to 5239.14
@BurrMan: "I use the built in Error notification/discovery supplied with MoI. " You mean "zooming in and examining", right? Or ist there something I have not discovered yet?
5239.18 In reply to 5239.17
Zooming in and examining is what you do AFTER the fillet errors.
Show messages: All  1-11  12-18
