question regarding using drawings / blueprints as templates
5232.1
Can someone who uses drawings or photos as sketch tracing templates take a look at the attached file.
I got it from www,the-blueprints.com. I left two sets of sketch lines, orange in color. The rectangular sketch is supposed to be the side window while the second single line viewable in the top view I just put there to check the images that I downloaded and lined up for tracing. Clearly things do not align when you place the points in the right place in each view.
So my question is, are the images that I got messed up or did I align them incorrectly? It looks pretty close when I zoom in and rotate in the 3D view but clearly something is WAY off. The view is set to parallel projection but my guess is that the images themselves have perspective in them.
Thoughts? Comments?
5232.2 In reply to 5232.1
Hi mjs - it certainly looks to me like the Right-side view, the one looking straight at the headlights, is some kind of perspective drawing.
Check out how much of an angle there is from the headlights back to the windshield, the red line here:
And compare that to the same thing in the top view:
Those images just do not match at all - it sure looks to me like the Right-side one looking at the headlights is some kind of perspective sketch.
5232.3 In reply to 5232.1
Deleted, do not think things will match up...?
The headlights and grill end of the car are much wider, and the windshield much narrower, than
in the other views.
EDITED: 2 Jul 2012 by BEMFARMER
5232.4 In reply to 5232.3
Here is one idea.
Add the front view TWICE, under different names, and hide one of the views at a time.
say:
1 = windshield view, and scale it up to match other views. (Ignore the grill)
2 = Headlight and grill view, and scale/align it down in size to match other views. (Ignore the windshield)
(could crop the rest of each picture, with photo software)
5232.5 In reply to 5232.4
EDITED: 22 Aug 2014 by BEMFARMER
5232.6 In reply to 5232.5
Yeah looking at the real photo, definitely that original front view is just some kind of perspective illustration, it's got a quite exaggerated perspective in it.
5232.7
Thanks all.
Now that you pointed out what I thought might be perspective in the drawings it stands out like a turd in cream.
Any recommendations for a site that has better blueprints for download without that issue?
The one I used does, I am sure, but I don't want to go through dozens of downloads to find ones that are ok.
Nice Dart. I had a 69 GT that I put a 360 into. Fun little 13 second car.
I miss muscle cars.
5232.8 In reply to 5232.7
The red front end seemed a pretty good match when substituted and added to your .3dm.
Seems like nearly all the photo's for the Dodge dart are taken at an angle.
For photographic perspective correction, of which I know nothing, did a google search of "remove photo perspective,"
and found http://hugin.sourceforge.net/tutorials/perspective/en.shtml
a free perspective corrector, and stitcher.
5232.10
I ask again,
Does anyone have a link to a website that has downloadable blueprints without perspective issues?
I appreciate the information on perspective fixing software but, if possible, I'd rather not add steps when I just like to play around with 3D modeling for fun.
5232.11 In reply to 5232.10
What model do you want ?
http://www.the-blueprints.com/ is not enough? Normally there is no perspective inside
Front, right ,top
5232.12 In reply to 5232.10
Hi mjs - I have had a look around and you seem to have the only ones out there, however there are numerous reference pics for front and rear views. May I suggest that you use the side views and top view in that set of prints, the car is pretty much a box on wheels and should not pose too much of a problem in MoI, then fill in the details for the front and rear by using reference photos. Again it should be pretty easy from what I have seen.
Sorry if that's not what you want to hear, but you will soon find out that there are very few real good prints that are out there. It is also in my experience that if you approach the manufacturers directly, they may very well send you old brochures and technical drawings especially for models that are no longer in production and are hardly considered to be conceptual property any longer.
Hope that helps :¬)
Martin
5232.13 In reply to 5232.10
The other night I looked very hard on google for any other blueprints, perhaps a hundred or more sites,
including numerous photographs.
Did not find any other blueprints. Found the same blueprints on several other sites.
The red front end was the best, and seemed to match up well with your current top and side blueprints.
There is one photo with some of the bottom of the car, at an angle of course :-)
There is a 3d model for sale.
http://www.hypr3d.com/ makes 3d models from your own photographs...
The preceeding post seems to be good advice to me...
http://www.foundationpc.com/brochure/68broch/cover.jpg
EDITED: 4 Jul 2012 by BEMFARMER
5232.14 In reply to 5232.13
Hypr3D seems amazing!
EDITED: 4 Jul 2012 by PILOU
5232.15
thanks for the efforts.
Kind of a bummer that there are not more resources online. Time to buy a scanner and make my own images to use.
