Video Tutorial: Temple Column
 1-19  20-30
522.20 In reply to 522.19
Hi Pilou, thanks for reporting this. Yes, I can repeat the same problem over here, it appears to be caused by a large spike in memory use while you are doing a transform command.
I'll take a closer look...
522.21 In reply to 522.19
Hi Pilou, this was a pretty bad bug, I have fixed it for the next beta.
It was partially related to undo - basically there were a lot of extra copies of objects that were taking up a lot of memory until you completed the transform command. With smaller objects this wasn't too noticable, but on a larger set of objects this could eat up quite a lot of memory and once enough memory is used so that you start swapping to disk, that usually slows things down quite a lot.
This is fixed in the next beta so that transform commands will not drain excess memory like this anymore.
Thanks for reporting this!
522.22 In reply to 522.21
:) I have always found that Moi has some difficulties speed with numerous objects :)
So happy that is resolved :)
Another question :)
In Google Sketchup when you "dupplicate" (or copy) an "objet component" (or an object "grouped") (say a box B) the result file size B + B is less than a simple box A + a simple box A
So when you have numerous same object's components or grouped : file is magically very small :)
example: a box B (grouped) * 100 = 44 kb
a simple box * 100 = 132 kb
Is it possible in Moi?
EDITED: 3 Apr 2007 by PILOU
522.23 In reply to 522.22
Hi Pilou
Some programs also call this type of thing "instances".
No, it won't be possible for the V1 version of MoI, but I would like to add instancing into a future version.
522.24 In reply to 522.23
I agree, instances would be very useful for large scenes. I think because Pilou and I are looking at MoI as an environment modeling tool as well, a feature like that would be nice. First though, I think a heirarchy/grouping system wold be best so we could manage multiple objects better.
Also, I just want to update everyone. I merged the whole video into one quicktime video. I plan to provide both a flash video and higher quality quicktime version of each of the tutorials I am planning to do. I finally figured how to get a decent sized quicktime video, 800x600, at a decent file size, about 1.1MB per minute with everything being hosted for free through blip.tv and Google services. Now I just need to get my mic back from a friend so I can record voice. This weekend I hope to finish up and post another video.
Eventually I want to record the process of rendering everything with Mental Ray as well as converting the models into normal-mapped real-time geometry for export into an engine like Visual3D.Net, Quest3D, or Deep Creator.
bitReality.blogSpot.com
(edit: updated image link again)
EDITED: 6 Apr 2007 by INNERACTIVE
522.25 In reply to 522.24
@Joe
this can interest you :).
ftp://ftp.formz.com/pub/formz/PDF_files/tutorials/column.pdf
(many more than a simple column !)
522.26 In reply to 522.25
This is indeed a very good tutorial. I did a column this evening using a similar technique. The new column I created is tapered and I used projected curves as rails to create solids to boolean out indentations and create fluted shafts. I figure it would be nice to introduce projected curves and booleans in my next video.
The capital represented in the tutorial you linked is very nice. I may attempt to re-create it tomorrow. Thanks again!
522.27
Thanks for the link Pilou!
I've learned quite a bit from this thread. Thanks to all.
Here is a quick one I did based on the pdf. It's not accurate and I took some artistic license but I like the results.
Moi:
Free Image Hosting at www.ImageShack.us
AO Render in Blender:
522.28 In reply to 522.27
Moderate Corynthian style indeed :)
Seems you must wait the next beta for move the entier temple without slow speed
522.29 In reply to 522.27
Yep, I've learned a lot from this thread as well. Very nice column capital you've built. I'm looking forward to attempting to model one myself.
522.30 In reply to 522.29
I recorded a short video of modeling a Doric Order Column I'll be uploading tomorrow. This is the style I want to go with for my temple. Thanks to Pilou for all the great reference.
Doric Order Columns
(edit: updated broken image link)
Show messages:  1-19  20-30
