after import from iges some meshes are double
All  1-8  9-15
5216.9 In reply to 5216.7
I had a quick look at ViaCad just now and will need to check it out a bit more.
Leonard
5216.10 In reply to 5216.8
Hi Leonard, thanks for attaching that rod model. I took a look at it closely and I do not see anything out of whack or unusual about it in any way, so I don't think there is anything you could do on the MoI side to change what you are seeing.
Since you also see that excessive density with just a regular sphere as well, as far as I can tell it's a problem that VectorWorks has with curved surfaces in general. You would need to contact them about improving that or modifying that behavior. Maybe there are some settings available that would allow you to adjust the density downwards somewhat - if those exist they are going to be settings on the VectorWorks side though that controls the behavior of their drawing generation mechanism. Since it's a mechanism in VectorWorks that needs adjusting there won't be any settings on the MoI side that you would use to affect that.
5216.11 In reply to 5216.10
Hi Michael, thanks for your help and I will check in with VW. If there is any news, I'll post here for VectorWorks users.
One final note, the problem might be the IGES>VW AND SAT>VW conversion. The images below are a VW-generated sphere (same 6" rad. as previous) and it results in about 85% fewer objects and 70% fewer lines in the final object.
Thanks for a great product.
Leonard
Size: 92.9 KB, Downloaded: 51 times, Dimensions: 722x443px
Size: 96.2 KB, Downloaded: 50 times, Dimensions: 712x424px
Size: 57.9 KB, Downloaded: 25 times, Dimensions: 713x447px
5216.12 In reply to 5216.11
Hi Leonard, check what kind of entity is created for the VW-generated sphere, does it really construct a truly curved NURBS sphere or does it make a set of polygons arranged in the general shape of a sphere? I would think it's likely the latter and that is probably the key difference.
Does VectorWorks also import polygon mesh data? If so maybe you should try exporting out from MoI as a polygon mesh object type (like .obj or .3ds formats for example) rather than as NURBS data, maybe that will tame things down.
5216.13 In reply to 5216.2
Hi michael,
again you are my hero. we get some unfinished cad-files from our customers to build virtual prototypes. It's a borring job to prepare and tesselate those files. I asked you a long time ago to colorize each meshgroup. You gave me a solution and with this help we can really quick import tose models into our software. The only bad thing are this double meshes. After i deactivated the "join surfaces" in your import option everything is fine.You saved us a lot of time and trouble.THANKS THANKS THANKs:)
Have an nice day.
Crydee
EDITED: 2 Jul 2012 by CRYDEE
5216.14 In reply to 5216.12
Hi Michael, we have, I believe, a happy ending.
Following up on your last post I tried VW Preferences>3D>3D Conversion Res set to medium (was "very high") and it worked! I had no idea, and no mention in the manual, that it applied to IGES and SAT imports.
The ceiling isometric was a good test for MOI working with VW, ergo clear sailing from here.
Thanks for hanging in there with me on this.
Leonard
5216.15 In reply to 5216.14
Hi Leonard, that's great news that you found a setting in VectorWorks to reduce the excessive density! Thanks for reporting that back here as well, that can help other people who might be using MoI and VectorWorks in combination in the future as well.
Show messages: All  1-8  9-15
