Problems with MERGE or TRIM commands
All  1-2  3
5212.3 In reply to 5212.1
Hi Mark, it sounds like you've got it all figured out already - yup if you extrude the outer piece you can then select it and use Boolean difference, selecting the inside wall as the cutting object. That will then divide the extruded object into 2 pieces and you can select the inner core piece and delete it to give you your desired result.
Show messages: All  1-2  3
