Feature Request - Update for new Mac Book Pro Retina Display
All  1-2  3-5
5211.3 In reply to 5211.2
thanks for the update. I suspected it may be a can of worms. My experience with the Retina display has been rather bitter-sweet.
The utility you suggested does actually work rather nicely for MoI. The text is small but adjusting the ui size to 20 and bingo.
Obviously, this works for MoI as its graphical in nature, other apps are madly small to say the least :-)
Thanks.
Gav.
5211.4 In reply to 5211.3
Hi Gav, yeah most apps do not have MoI's same ability to scale the UI to any arbitrary size, so that "full screen resolution" method probably won't work too well as a full time mode.
But if you know that you are going to spend a chunk of time in MoI then doing that resolution switch may work for now anyway.
Can you test something when running under the regular Retina resolutions - what happens if you right-click the MoI .app and then pick "Get Info" then on that panel that comes up in the "General" section near the bottom there should be a checkbox labeled "Open in Low Resolution". Is it possible to uncheck that or is it grayed out?
5211.5 In reply to 5211.4
sorry for the slow reply.
The flag is current unchecked and unselected. I have played around with this and the plist options in MoI and Wineskin, but it changes nothing.
The best option is still to switch res and increase the UI.
Ta
Gav.
Show messages: All  1-2  3-5
