Pipe2 not working
All  1-11  12-15
5210.12 In reply to 5210.11
Hi Felix, I'm sorry I just don't have any idea how Pipe would affect other apps that way. You mean it affects other apps even after the Pipe command is finished? Or only while it is running?
Maybe there is some problem with your video driver and it is manifesting itself in strange ways like that. That's about the only thing I can think of, maybe try to update your video driver to the latest version and see if things improve any...
And yes, the original Pipe command did need an update in order to run on v3, the version you need is the one from here:
http://moi3d.com/forum/messages.php?webtag=MOI&msg=4438.41
5210.13 In reply to 5210.12
Michael,
I tried restarting my computer and use Pipe again, this time it work fine and didn't affect anything else as far as I can see. I also tried Pipe2 but this one didn't work and still cause other stuff to happen.
It looks like my mouse and keyboard are affected as I can't switch to other apps that are running but when I close Moi, every thing seems to be ok. I'm using a few other scripts since version 2 ( before V3 was out) and nothing like that happen even with Pipe2 until april 16 beta.
I wonder if we could setup somekind of remote session where you could see for yourself what's happening. Maybe it as nothing to do with Moi but I'd like to be sure.
Felix
5210.14 In reply to 5210.13
Hi Felix, did you try updating your video driver?
The april 16 beta only had minimal changes from the previous v3 beta before that, so that is pretty weird.
Also it's strange that everybody else who has tested it so far hasn't been able to reproduce any problem...
Are you possibly running any kind of anti-virus or anti-spyware system that might be interfering with MoI's operation? I'm really just grasping at straws though since I don't have any good idea why it does not work for you.
5210.15 In reply to 5210.14
Michael,
I agree it's very likely it as nothing to do with Moi as I install quite a few programs and it's very likely one of these is causing the problem. What I find bizarre is it would seem that only Pipe2 reveal something is wrong. The simplest solution for me is not to use Pipe2 anymore for the time being.
As for the video driver, I didn't do anything with it as far as I can recall but I wouldn't bet on it, bad memory.
Felix
Show messages: All  1-11  12-15
