Getting a curve to follow a shape that tapers?
All  1-7  8-10
5208.8
Wow thanks guys for your input I'll be trying these later on.
Lang
5208.9 In reply to 5208.8
Hi Fabien
Would you mind giving me a more detailed description of what your doing with that twist method as I can't work it out.
I've tried the drawing the curve directly onto the dome that works well, thanks Michael, but I'm having all sorts of problems getting the sweep right. I see what you mean about how hard that may be to get right.
Thanks guys
Lang
5208.10
Hi all
I've been playing around with the twist and sweep function and am getting there I think. Still not perfect but may be good enough for what I need. I sweeped the curve with 3 different circles as these work quite well around the tapering shape of the dome. No matter how I do it otherwise I can't seem to get say an oval to work how I want it so maybe one of you more experience guys out there can help me out on that one?
I have another issue going on here with the file attached. Basically I can't fillet the edges around the sweeped boolean shape to soften the edges and have come across this problem a few times. The object is unified and joined so don't know why it won't fillet. I've also tried using a very small fillet amount to begin with but that won't work either. I reckon its going to be something really simple no doubt that I'm missing here.
Thanks again for any advice here folks
Lang
Show messages: All  1-7  8-10
