Rounding/Conversion Error in Viewport
All  1-4  5-10
5196.5 In reply to 5196.4
Wow... I really couldn't have asked for better support. Thanks for your insanely quick and spot on responses!
I've been working in inches (not my own preference, but for US manufacturing it is easier) and haven't really encountered sizes larger than 100 before! And yes, if I just click on the number it now displays properly (for some reason I had it in my head that setting the 5 trailing zeros would stop the rounding in the viewport, and forgot that very basic operation to check the value!). I think there is still some unit conversion oddity that is going on, but it looks like the real issue is a misunderstanding I had with the UI!
Michael, I will PM you the file in it's original inch setting so that you can check the unit conversion and let me know if this seems off.
FDP
5196.6 In reply to 5196.5
Hi FDP - thanks for sending the file. I cannot find any error in the conversion there aside from the display rounding issue mentioned above.
Your line that is labeled "This should be 6.35mm" starts out at 0.25 inches, and when switching units to mm if you select the line it does indeed read out as 6.35mm .
Your rectangle that is labeled "This should be 170mm" starts out at 6.69 x 6.69 inches (which you can double check in Rhino using the BoundingBox command in there), and after conversion to mm it is not 170mm but that's because 6.69 inches does not convert to exactly 170 mm, 6.69 inches actually converts to 169.926 millimeters.
6.69 x 25.4 = 169.926
If you convert from inches to mm in Rhino and then use BoundingBox in Rhino you'll see the exact same result as in MoI - your rectangle gets a millimeters size of 169.926 x 169.926 in Rhino as well.
It looks like your size in inches is rounded slightly when it was originally entered? If you wanted a size of 170 mm the equivalent in inches is not a nice number with limited digits, it's something like: 6.6929133858267716.... etc
So your original value in inches is truncated and didn't get close enough to what you'd need to get the equivalent of 170mm. You maybe should create it in mm to start with, or while you're in inches you can enter in values with mm at the end which will then do a higher accuracy conversion for you, like if you draw the rectangle in unit inches enter in both 170mm in the text field for width and height and you'll then get what you wanted.
How was it that you originally created the rectangle, did you type in 169.926 as the values for width and height?
Anyway, that's why the rectangle does not convert to what you were expecting, it's because it's not actually at that size.
5196.7 In reply to 5196.6
Yes, It was definitely 100% confusion all around. The reference document we were using had the wrong conversion for the 170mm to inches conversion. Somewhere in the confusion whoever it was that checked the conversion yesterday (probably me) just went back to the reference instead of using a calculator...
Thanks for taking your time to help and giving such excellent support to your customers, even when they are chasing after phantom issues!
Best Regards,
FDP
5196.8 In reply to 5196.7
Hi FDP, no problem, I'm glad you got it all sorted out now!
And sorry about the rounding in the MoI properties panel display adding more to the confusion - that was really a mistake on my part to worry so much about fitting large stuff in there so much, for the next v3 beta that will be switched to not do that extra rounding and you can apply that change to either v2 or the current v3 using the updated file at those previous posted links.
5196.9 In reply to 5196.7
Oh now that I checked, it turns out that the updated UI files that I posted previously only disable the rounding for "feet & inches" type display, not decimal type numeric display. I'll post another update here a bit later that will disable the rounding of larger values for decimal numeric display as well.
5196.10 In reply to 5196.7
Hi FDP - attached here is an update for the current v3 beta which should actually disable the additional rounding on decimal values of 100 or greater, to update your installation copy the attached file over top of the old version which is inside of the \ui folder inside of MoI's main installation folder.
Let me know if you are using v2 instead of the v3 beta, on v2 it's a slightly different file that needs to be updated.
Show messages: All  1-4  5-10
