What is the material of the little plat pierced disk?
How is made the waterproofness? a plat "form" over a circular "form" --- ist it excavated behind?
Is beautiful that please without concept! My Gallery
Wow, your putting some thought into this ;) It's actually a hydraulic actuating cylinder retained in the body cavity by the bolt pattern used to store the outer tension ring assembly in a profile when not in use. The twelve yoke assemblies actually have wire hydraulic tensioning assemblies connected to them for a total uplift capacity of 1,900,000 lbs force. The bulk of the unit is coated with a three part marine epoxy paint system and the cylinders you pointed out are coated with xylan to inhibit corrosion but is now being coated with sermagard as it has better UV resistance.
The one difficult thing about the icon is that there also needs to be a teeny-tiny 16x16 version of the icon as well, which is used on the task bar and also shows up in the title bar of an unmaximized window.
So that's one reason for the rather basic icon right now, because the same image makes a pretty legible tiny 16x16 image.
I guess I could have a different style image for the larger icon versus the tiny one.... I'm not quite sure about that though.
I don't know what you use to create an icon, but there is a nice app which comes from Czech Republic - http://www.rw-designer.com It has even NURBS (http://www.rw-designer.com/NURBS) tools for making stuff! :) ...and there is some library of free icons as well - for example a bulb... -Petr
Hmm... the light bulb is cool, but didnt Michael say it leans more towards Moai (the Easter Island heads) rather than the French "moi" (me). How about a glowing Easter Island dude? :) Hehehe, he is inspired no?
