Majik Tutorial: The Mach-16 Razor
 1  2-21  22-26
5188.22 In reply to 5188.21
Hi SanSingh.
I downloaded your 3DM file and for what I briefly checked I think that the main problem are the Red and Blue curves.
1) The red curve is a single curve made by two segments not well joined.
2) And, furthermore, even the blue curve is one single closed curve.
As you can see in the video I have simply deleted the red curve and I trimmed the blue curve.
Then I selected ALL and performed the Network command.
Hope this can help :)
Here's a video capture of Moi's screen : http://take.ms/B69p6
Here's the modified Moi file : http://take.ms/qWMGB
Here are some screenshots :
5188.23 In reply to 5188.22
Hello, you are absolutely right!!!
So i guess i didn't need to select the red curve when running the network command and
i needed to split the blue curve into two.... Wow, i would have never figured it out.
Thank you so much. I really do appreciate your help and quick feedback.
Thank you thank you! Have a blessed day!
Sandeep.
5188.24 In reply to 5188.23
You're welcome SanSingh!
Best.
5188.25 In reply to 5188.22
Marco,
<<Marco (mkdm)>> Here's a video capture of Moi's screen : http://take.ms/B69p6
Where did you get that command history panel?
Is it generally available?
-- MindSet
5188.26 In reply to 5188.25
Hi Mindset!
> You wrote : "Where did you get that command history panel? Is it generally available?"
No. It's my very personal version of Moi :)
It's made by some personal scripts and UI Personalization that I did some times ago.
It contains also a very useful command search engine window, wrote by me (I was inspired by some great script written by Max Smirnov and others)
If I will have the chance to clean its code a bit and I will have some spare time I think I will upload my whole Moi's App folder.
It will be my gift to the community!
See you.
Show messages:  1  2-21  22-26
