Majik Tutorial: The Mach-16 Razor
 1-17  18-26
5188.18 In reply to 5188.17
I totally agree, Mike, both with the beauty of math and the beauty of MoI.
Looking eagerly forward to your next tutorial!
metinseven.com — 3D (print) modeling • animation • artwork • design • illustration • visualization
5188.19
Hello, i hope all is well.
I thought i'd give this tutorial a shot.
I am currently stuck at the network stage. After creating the profiles and running the network command,
the calculation fails. Can you please help? What could be wrong?
I look forward to your help : )
Cheers.
Sandeep.
5188.20 In reply to 5188.19
Post your 3dm format file! ;) (zipped if possible)
5188.21 In reply to 5188.20
Hello Pilou,
thank you for your speedy response..
I work on a Mac, i hope the file opens. Please find attached.
Thank you.
Sandeep.
5188.22 In reply to 5188.21
Hi SanSingh.
I downloaded your 3DM file and for what I briefly checked I think that the main problem are the Red and Blue curves.
1) The red curve is a single curve made by two segments not well joined.
2) And, furthermore, even the blue curve is one single closed curve.
As you can see in the video I have simply deleted the red curve and I trimmed the blue curve.
Then I selected ALL and performed the Network command.
Hope this can help :)
Here's a video capture of Moi's screen : http://take.ms/B69p6
Here's the modified Moi file : http://take.ms/qWMGB
Here are some screenshots :
5188.23 In reply to 5188.22
Hello, you are absolutely right!!!
So i guess i didn't need to select the red curve when running the network command and
i needed to split the blue curve into two.... Wow, i would have never figured it out.
Thank you so much. I really do appreciate your help and quick feedback.
Thank you thank you! Have a blessed day!
Sandeep.
5188.24 In reply to 5188.23
You're welcome SanSingh!
Best.
5188.25 In reply to 5188.22
Marco,
<<Marco (mkdm)>> Here's a video capture of Moi's screen : http://take.ms/B69p6
Where did you get that command history panel?
Is it generally available?
-- MindSet
5188.26 In reply to 5188.25
Hi Mindset!
> You wrote : "Where did you get that command history panel? Is it generally available?"
No. It's my very personal version of Moi :)
It's made by some personal scripts and UI Personalization that I did some times ago.
It contains also a very useful command search engine window, wrote by me (I was inspired by some great script written by Max Smirnov and others)
If I will have the chance to clean its code a bit and I will have some spare time I think I will upload my whole Moi's App folder.
It will be my gift to the community!
See you.
Show messages:  1-17  18-26
