shortcuts for aligningobjects
All  1-3  4-8
5184.4 In reply to 5184.3
> So just write for example Align VerticalRight in the second column
> of the Shortcut Menu ?
Yup, that is correct - with this updated version of Align you would put Align VerticalRight in the second column (the one that says "Command") to make align start up and also use that particular mode.
5184.5
Hi All
I give it a try, but instead to execute the specific align option it just uses the last used option. Can anyone confirm this?
nos
5184.6 In reply to 5184.5
Hi nos - I tested it and it was working ok over here.
Did you possibly only set up the shortcut keys that were listed but did not copy over the updated Align.js file as described above?
Because if you have the original version of Align you would get the behavior you are describing - you need to update the Align.js file before those shortcut keys with the parameters in them will work.
5184.7
I thought I copied it, hoever I copied it "again" und now it works, thanks for the script.
nos
5184.8
(Scratch my earlier comment - I placed the Align script in V2's command folder instead of V3)
I was able to actually use the same key commands that I've been using with Corel for the past umpteen years, so this is awesome - those alignment features come naturally to me.
This is something I wanted too.
EDITED: 18 Jun 2012 by MAJIKMIKE
Show messages: All  1-3  4-8
