Reshaping form using control points?
All  1-12  13-18
5183.13 In reply to 5183.10
Hi Colin, re: Clayoo - it sounds like it's a sub-d modeling system running in Rhino but it generates polygon output at the moment and not NURBS output.
But according to this discussion here it sounds like it will be targeted in the future to do that:
http://www.clayoo.com/forum/topics/first-thoughts
5183.14 In reply to 5183.13
"""""""""Flow does not have it enable by default so you have to select its output and enable history updates on it before you will see history being applied to it.""""""""""
Ahhhh. I was tricked! Control point editing on flowed objects.. Kindof like pulling cage points! Jojo was a wabbit.....
5183.15 In reply to 5183.13
Thanks for that info.
I believe there's a number of the jewellery guys who are giving Clayoo a try.
It'll be interesting to hear back what they think of it.
regards Colin
5183.16
Cheers for that. Those hulls look good. I think it's best when the cage is just visible enough not to be hard to use, but so it doesn't obstruct the model at all. It would be nice to be able to customise the look.
Interesting looking app Colin.
Michael, now you mention it, is there a script to turn on history updates for everything, by default?
5183.17 In reply to 5183.16
Hi Playdo,
No, there's not currently any way to change the defaults for what things have history automatically turned on and what things don't.
But you can turn on updates for all objects currently in your model by doing a select all and then do Edit > History > Enable updates.
5183.18 In reply to 5183.17
That would be a handy checkbox to tick ;)
Cheers for clearing that up, and my other post too.
Show messages: All  1-12  13-18
