Blend
All  1-4  5-8
Here is the prior post on this: http://moi3d.com/forum/index.php?webtag=MOI&msg=5029.1
I believe the following is (mostly) correct.
Blend currently works with only two items at a time
With regard to the cylinder, Blend works with the edges, not the curves which may lay on top of the edges, so hide or delete the curves.
Mousing over the unselected cylinder, highlights (some) edges.
Select the cylinder after the curves have been deleted, then mouse over the edge to be selected.
Also need to delete any top or bottom face, or often its edge will be selected, not the edge of the cylinder.
5181.6
Lang,
Here's the way I tried it:
1) Create at Square with rounded corners and your circle.
2) Enter the "Rebuild" command to re-create you rounded square to become one path.
3) Extrude the circle and square
4) Blend between the two surface edges.
Since each edge will be composed of one curve, Blend should tangent the surfaces nicely.
One of the many ways you can attack the problem with MoI
5181.7 In reply to 5181.1
Hi Lang, looks like you got a lot of various feedback here with some things to try, please let me know if you are still stuck with this.
5181.8
Fantastic response guys. And thank you Michael. I'll be giving these ideas a go later and will let you know how it goes, thanks again.
Show messages: All  1-4  5-8
