Texture around model for 3D printing
All  1-2  3-7
5180.3 In reply to 5180.2
Hi Martin,
Thanks very much for your advice, much appreciated. I'll go for the final option, I have nothing to lose (except my mind!)...it's worth a shot...how would I go about doing this in Moi?
Many thanks again
Wooly
5180.4 In reply to 5180.3
"""""" I'll go for the final option"""""""""
Can you give some type of example of the model and texture you are talking about?
5180.5 In reply to 5180.4
sorry, the model is a cube 8cm3. I have attached an image of the texture I'd like to wrap around it.
5180.6 In reply to 5180.1
Hi Wooly, yeah like Martin mentions above a "displacement" map is more what you want for actually altering geometry rather than just a visual only effect like bump mapping.
Then different programs use some different kinds of terminology for generating the displacement as a stand alone model rather than just generating geometry at render time alone. Sometimes it's called "freezing" the model, and sometimes it may be a special tool - I think in Rhino it's called ExtractRenderMesh (or possibly "ApplyDisplacement"), although I'm not 100% certain - you should probably ask on the Rhino discussion list if you can't find it.
MoI does not have any function in it currently for modifying an object by applying a bitmap texture onto it - typically that kind of texturing is done to polygon mesh objects and MoI specializes in NURBS surface editing and not polygon mesh editing.
MoI does have a command called "Flow" which does allow you to apply geometry onto a target surface kind of similar to texture mapping, but it's not a bitmap being applied, it's other objects being applied. See here for some more info and examples on that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4856.2
There's also a free program called ZSurf which can build a "heightfield" NURBS surface based off of a bitmap, that may possibly be of use:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3825.2
But if you want something that works exactly like displacement mapping by applying bitmap textures, you probably want to be looking at using some kind of polygon mesh and rendering oriented program for producing that specific effect instead of doing that directly inside of MoI, since MoI is not itself focused on editing polygon mesh geometry.
5180.7 In reply to 5180.6
Thank you very much, I will try those out.
I appreciate your help.
Aysha
Show messages: All  1-2  3-7
