SpherePoints Script, evenly (more or less) distributed points on a sphere, by Golden Section Spiral
 1-2  3-22  23-25
5177.3 In reply to 5177.1
Done with SpherePoints version 2. See second post up.
For a solid sphere, I was unable to get an internal pointing array, with ArrayGem. Can get it with Orient.
With a circle revolved 180 degrees, forming a half sphere, and rotating a copy to make a full sphere,
ArrayGem created inward facing cones.
EDITED: 13 Jun 2012 by BEMFARMER
Size: 321.7 KB, Downloaded: 50 times, Dimensions: 756x621px
Size: 152.1 KB, Downloaded: 42 times, Dimensions: 736x721px
5177.4 In reply to 5177.3
For 10, 20, 100, 200, and 50 antipodal points, ran ConnectPoints script on the points.
Depending upont the tolerance, from 0.4 to 1.5, produced a convex hull of edges, +/-, with sometimes some
extra inner lines. The more points, the lower the tolerance should be...
Sometimes planar does one face. Need an edgewalker script. :-)
5177.5 In reply to 5177.4
Hi Ben,
you could try also the following to get faces quickly. Simply save the point file with an .asc extension and then load it into Meshlab and in the "Remeshing, etc." menu apply ball pivoting surface reconstruction. Then save as .obj and use Michael's new Obj23dmWireframe converter with the new option and voila you can create quickly a surface for your sphere/dome or make a solid out of it.
EDITED: 29 Jun 2012 by STEFAN
You have some volumes in the free Wings3D too who maybe help you! ;)
http://www.wings3d.com/
5177.7 In reply to 5177.5
Thank you Stefan, for the meshlab instructions.
I'll try it out. Did read about .asc and meshlab recently, and how to enable renaming extensions in
Windows 7.
5177.8 In reply to 5177.6
Thank you Pilou.
5177.9
SpherePoints+
This is enhanced version of the one of my favorite scripts.
[Added] Significant performance improvements (>30000 points per second)
[Added] Radius tuning
EDITED: 7 Mar 2022 by SMIRNOV
5177.10 In reply to 5177.9
Max, you have made great improvements!
I've got to study this, in order to try to adapt some other scripts to this faster method.
How did you learn to program so well? Xgood?
EDITED: 25 Jan 2014 by BEMFARMER
5177.11 In reply to 5177.10
Thank you, Brian.
It's easy. You need to move all geometry active functions to .htm (especially functions with loops). It's no need to move all functions. But you must be careful when you place heavy functions in htm. If you run such a function, it causes MoI to hang until calculations is finished. So I prefer to send data to function part by part. In addition I use progress bar.
Like this:
Also in SpherePoints script I changed a method that creates points and lines. I don't like a huge pile of factories, so now this script generates objectlist directly, using only one factory.
>> How did you learn to program so good?
:)) Programming is my hobby for the last 25 years (but it's not my only hobby :). I'm not a professional programmer or 3D designer.
5177.12 In reply to 5177.11
Thanks Max.
Where does the progress bar come from?
PS How do you use the result of the radial lines for have your sphere of colored cones ? - not the colors but for place the cones ? Post 5177
You said Array Gem but how ? Lines are not curves and there is no surface...so ...I must miss something :)
EDITED: 25 Jan 2014 by PILOU
5177.14 In reply to 5177.13
Create -SpherePoints and lines.
Create a cone and base circle.
Create a sphere.
Do ArrayGem, select cone and base circle.
Select lines, (do not re-select base circle). (Helps to color select the lines, or temporarily hide the sphere.)
Select sphere.
Done
Was able to do 100,000 points, and lines, with Max's _SpherePoints. It only took a few seconds. Haven't tried a million yet.:-)
Calculate is long but Perfect!
Cones are inversed! :)
So maybe Flip lines before ?
EDITED: 26 Jan 2014 by PILOU
5177.16
Brian
This is my new script for exporting instances data from MoI to Octane Render.
Frenchy Pilou
1000 cones ~3-4 seconds
>Cones are inversed! :) So maybe Flip lines before ?
No. Everything is correct.
Maybe you're doing it wrong?
EDITED: 8 Feb 2014 by SMIRNOV
5177.17 In reply to 5177.16
Cool video : i will exam that i make different! First view nothing :)
Second view...there is something but what? :)
Maybe a bug inside ArrayGem ? Or I Input a false espacement or...Unity...or...
What did you made at 0.012 ? Lines becomes points dashed
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/conesbug01.3dm
For a while today, I could not get ArrayGem to work. Maybe something to do with the ArrayGem spacing.
Then after practicing with a curve on a cylinder, with spacing, ArrayGem worked again.
So then with SpherePoints, I learned that doing Flip on the base circle, caused the radial direction of the cones to reverse,
with respect to the sphere.
So maybe ArrayGem spacing matters? And radial length of the lines?
Also the normal of the base circle matters.
Flip of the radial lines puts the focus on the center of the sphere.
5177.19 In reply to 5177.18
Hi Pilou, yeah I guess you have somehow created your base circle for ArrayGem in some way such that its default plane normal is going downwards instead of upwards.
So select it and go to a side view of the circle and use the rotation grip on the edit frame to rotate it by 180 degrees, that should then get it oriented how you need it in relation to the base object.
5177.20 In reply to 5177.17
I checked your file. Аll the same. I think that the easiest solution - turn the base circle.
script:/* wireframe v1.0 */ var gd = moi.geometryDatabase; var so=gd.getSelectedObjects(); if (so.length>0) { so.setProperty( 'displayMode',1); so.setProperty( 'selected', 0); } else { gd.getObjects().setProperty( 'displayMode',0); }
This is another my script. I use it very often.
It switches selected objects to wireframe mode. If no objects is selected - it switches all hidden objects back.
P.S. I think I should make a website to share ALL my scripts with community :)
Ok ! That was the orientation of the base for an half parts for mysterious reason! :=)
<<< P.S. I think I should make a website to share ALL my scripts with community :)
Sure! That will very cool !
And your video shows that your computer is maybe 500 faster that mine for th cones! :)
You have also on your video a List Menu with some Plugins clickable!
How do you make this list ?
Have you a plugin for make this list ?
Or Maybe Michael has some views on this for next releases ?
EDITED: 27 Jan 2014 by PILOU
Show messages:  1-2  3-22  23-25
