Triangular Pyramid with rounded ends.
All  1  2-3
5161.2 In reply to 5161.1
Hi Brian, you might try something more like - draw in a profile curve:
Revolve that with "Cap ends" off to make a rounded surface like this:
Select the pyramid and use Boolean difference with that revolved surface as the cutting object - that will chop off the point of the pyramid which you can delete:
Now the rounded surface is imprinted into the tip and to make it be connected smoothly to the side faces select the top face:
And then use Construct > Fillet to make smooth connection pieces:
So basically try to more directly model the rounded tip shape and let it be initially sharp where it hits the pyramid, then use filleting to smooth it.
5161.3 In reply to 5161.2
Thank you Michael.
Show messages: All  1  2-3
