Microsoft jscript error
 1-19  20-22
5145.20 In reply to 5145.19
Thanks for all your help Michael! I finally got things up and running. FYI, I discovered that MoI couldn't see the point file when it was saved in Rhino V4 but when I saved it again in Rhino V2 it worked fine.
Cheers!
5145.21 In reply to 5145.20
"""""""""" I discovered that MoI couldn't see the point file when it was saved in Rhino V4 but when I saved it again in Rhino V2 it worked fine.""""""""""""
See if you can create the 2 different ones and post them here, so we can see the difference.
5145.22 In reply to 5145.20
Hi Cecil, most likely Rhino v4 created a particular kind of "point cloud" entity when you imported the point file. Right now MoI only looks for individual point entities and does not handle that "point cloud" object type.
If you run the Explode command in Rhino it would probably convert the point cloud into individual point objects and that would then work saving as a 3DM file type - when you export to a v2 3DM it basically does the explode step for you right then automatically.
Show messages:  1-19  20-22
