New Mar-29-2007 beta available now
 1-7  8-27  28-34
513.28
Strange at office it works just fine, but at home none of the drop down boxes seem to work. I noticed when trying to set the system units, but found out none of the drop down boxes throughout the program seem to work. When I click the text in de box or the arrow to the right of the box the text get 'selected' by a dashed rectangle. But nothing else happens.... WinXP Pro btw
edit: it happens with the previous version too :( (would be nice if i could try Moi3D at home too), so I guess it's a video driver thing ?? (GeForce FX5200)
EDITED: 3 Apr 2007 by TARANQ
513.29 In reply to 513.25
>>Not directly, just as I was testing the edge offset it happened to remind me that
>>I should tune up join to allow edges as well.
Maybe, Join could work like Rhino's _MergeEdge with edge selection. It would be useful when I want to grab a edge as a rail for sweeping... -Petr
513.30 In reply to 513.25
>>There isn't really an offical way to mark an IGES file as having "no units".
>>And the IGES spec says that the default value for units should be value "1" which is inches.
If it's true, you ought to leave it in current way otherwise you could blame for making a can of worms (this is the IGES's nickname as labeled by Ashlar-Vellum :)
>>Do you have any other software that has a "no unit system" setting and also writes IGES files?
I thought MoI without unit system had written "none-flag". I checked Jan-18-2007 beta... I must say I was wrong...
Petr
ps:
Note that Rhino allows writting IGES with unit flags of "0" (none) or "3" (undefined). When I import it in CAM software (AlphaCAM) I get a warning for "0" flag (flag of "3" is OK):
*** Warning (IEVM_BAD_GLB_UNIT_FLAG) ***
The Unit flag (Index 14) in the IGES file's Global section is 0, which is outside the valid range of 1 to 11.
Action taken: The Unit Flag (Index 14) in the Global section has been changed to 1.
*** Warning (IEVM_BAD_GLB_UNIT_FLAG_MATCH) ***
In the IGES file's Global section, the Unit flag (Index 14), 1, and Unit string (Index 15), , specify conflicting units of measure.
Action taken: The Unit string (Index 15) in the IGES file's Global section has been changed to IN.
EDITED: 4 Apr 2007 by TYGLIK
513.31 In reply to 513.30
Here's a short screengrab so you can see what happens .... or better what doesn't happen ... :( concerning the drop down box problem..
EDITED: 4 Apr 2007 by TARANQ
513.32 In reply to 513.31
Hi TaranQ - have you tried rebooting your machine since this has been happening? That might be worth a try.
One other question - do you know if your machine was updated from IE6 to IE7 recently? If you have IE7, you might try pushing the IE "Reset" button - this is mentioned on this blog page: http://blogs.msdn.com/ie/archive/2006/06/12/628499.aspx - it is in IE under the Tools menu / Internet Options / Advanced Tab, then there is a Reset button at the bottom there.
Actually this one is probably not due to video driver issues. MoI actually hosts a mini Internet Explorer panel to display the UI there, and something is not working right with IE on your system there. That's why an IE reset may help.
One other experiment you might try - after you click on the dropdown and get the dashed rectangle on it, try using Alt+down arrow on the keyboard and see if that opens up the dropdown or not. That is a keyboard shortcut for opening drop-downs, if that works then it narrows it down to something involving clicking rather than the drop-down itself being broken somehow...
513.33 In reply to 513.32
Hi TaranQ - another thing, from your screenshot AVI it looks like you may be using some kind of system skinning tool like Window Blinds? If so you might try disabling that to see if it is causing this to happen.
513.34 In reply to 513.33
I can indeed select de different options in the drop down menu by using the arrow keys after selecting the box. It doesn't however actually drop down.
mmm could it be the vista brico inspirat transformation pack ??? haven't had any trouble with other programs till now allthough it's installed for over a year??
edit : have even de-installed the vista brico pack (Description : BricoPack Vista Inspirat is a free pack which modifies Windows XP system files in order to change its appearance and make it look like Windows Vista.) but that didn't make any difference.....
Resetting IE doesn't make any difference either...
Show messages:  1-7  8-27  28-34
