Creating a complex shape
All  1-8  9-11
5123.9 In reply to 5123.3
BurrMan
I do like what you have done here with just these two curves.
Yes, could you please describe what you did?
Scott
5123.10 In reply to 5123.9
Hi Scott,
Here's a video of how I made the example.
http://youtu.be/LtElXqa6dDM
In the video, I talked about a poor decision in my model to create a "radiused curve" in the originating curve, instead of a hard edge.. This can create problems later.
I tried to make note of showing how the red curves from your original model are trying to mimic what the fillet creates. Trying to hand model those would be hard. I suppose the trick is to figure out what the original shapes and orientations are that would have the fillet edges match a "picture" or somthing...
I also think that if you are trying to "totally match" from a picture, you may get better results by using a revolove, instead of the blend i use, on the initial pod shape.. Revolving half of that curve, then turning on control points will allow you to change the shape in a way to match your base curves you started with...
5123.11 In reply to 5123.10
BurrMan,
After trying many different beginning shapes and tools, I finally went with your suggestion and started with a basic ellipse shape.
Then, I created a bulge via the blend tool, mirrored it and shaped it.
Next I created 3 ellipses that matched the shape of the upper section.
I then did a loft through those three curves.
From there, it was easy to merge those two pieces together.
Then came the small camera in the front. I did have a small issue with creating a fillet and had to do it manually. Thanks Jason.
This was all part of a model of LUNA, a German UAV that I'm building for one of our customers.
Thanks for all your help.
Scott
Show messages: All  1-8  9-11
