Show Points shortcut
5116.1
This is a terribly lame subject for my first post here, but is there a script (internal or otherwise) for toggling visibility of points? I know you can hit escape to turn them off, but I can't find a way to turn them on (short of using the button).
5116.2 In reply to 5116.1
Hi Brandroid, put in:    ShowPoints
as the command part of the shortcut key and then pressing that key should do the same thing as clicking the Edit > Show pts button.
That will work for both turning on points and also turning off points as well if the selected object already has points turned on.
5116.3 In reply to 5116.2
Thanks Michael!
