The new OSX version
All  1-3  4-10
5115.4 In reply to 5115.2
That works, made a note of it. Thanks again for making modeling fun on both platforms. Cheers
5115.5 In reply to 5115.4
What happened to the OSX beta download? The file shows the old Jan 31 version.
5115.6 In reply to 5115.5
Hi jtucker,
It's probably your web browser showing a cached old version of that web page.
Try pushing F5 or using the "refresh" or "reload" button on your browser and you should probably get the actual current version of the page.
5115.7
Bug Report.
Not sure this has already been reported Michael, but when you are editing style in the Mac version and you select a "crayon" color and do not close the crayon menu and try and type the name of your new style, it doubles your letters. This does not happen if you close the crayon select menu.
Not a major bug for sure, but a slightly odd one.
5115.8 In reply to 5115.7
Hi Paul, thanks for reporting that - that color picker dialog is supposed to actually supposed to be "modal", meaning the edit style dialog should be disabled until you finish picking the color but that's not working properly. I should be able to fix that up pretty easily though, thanks for reporting the bug!
5115.9 In reply to 5115.8
yo,
Your latest osx beta has version 2.5 to it, instead of the previous 3. There a reason for this? did you leave out some features?
just curious.
sven
5115.10 In reply to 5115.9
Hi sven, no there haven't been any features left out, it's the same modeling features as the previous v3 beta, just with various OSX-specific stuff refined.
The difference from the previous v3 labeled version is the release schedule - rather than waiting to release a final OSX version until the entire v3 beta process is complete which will be quite a while yet, I decided to finish up an OSX release with the current v3 beta feature set and call it version 2.5 .
Otherwise if I just released it as a regular v3 beta it was kind of a weird situation because normally betas are only open to existing customers, but the only previous versions have all been Windows versions so it was weird for someone to need to purchase the v2 Windows version in order to have access to use the OSX beta. That situation was the case with the first OSX beta but due to feedback about that I switched plans to have a nearer term 2.5 release instead and also to make the betas for the 2.5 release to be open to anyone.
Show messages: All  1-3  4-10
