V3 beta
All  1-7  8-11
5100.8 In reply to 5100.7
Thanks for that reply, for this experiment I was simply using the files Matt supplied, I haven't got MOI on my machine, is beta V3 available as trial version? Anyhow you are right the text looks pretty good, but you know what it's like when your trying different things out it's always great if you can get a robust mesh with all polys and verts joined, by going to sub-ds in modo you can add more mesh detail which is great for sculpting and displacement if you want to work the text or any object further done the line, great on close ups etc.
Michael if V3 isn't trial would it be a problem to supply a "&" as a text object in LWO format so I can have a play in modo with it...and push it up here for download...
Andy
5100.9 In reply to 5100.8
Hi Andy, MoI can produce a mesh with all polygon vertices joined making a "water tight" mesh but that's a different thing than an "all quads" topology. To get a sub-d capable mesh you need more than all vertices joined, you need particular care in the edge flows and topological structure and that's typically something you get using your judgment and experience in arranging the polygons, not something that will come from an automated conversion mechanism.
If you want to do close-ups on small areas you just export a higher density mesh out from MoI and then render that.
If you're going to be doing sub-d modeling on the mesh, then mostly you should build the base meshes for such things yourself and not as a conversion process though. MoI will not be the right tool for the job if you need to do that type of stuff.
Re: v3 - sorry there isn't a trial version of v3 currently, there will be once v3 is released but that's a ways out yet.
I've attached an Ampersand LWO file for you here.
5100.10 In reply to 5100.9
The infinite demo (without save) is what version ?
5100.11 In reply to 5100.10
V2, same as the 30-day trial version.
I will update both of those trial versions to v3, once v3 is actually finished and released.
Show messages: All  1-7  8-11
