Gillette razor Mach3 recreated with moi3d
 1  2-21  22-24
5083.22 In reply to 5083.21
Hi koleos,
Thank you for the link, I'll have a look. My knowledge with blender is a total of about a couple of hours or so. Downloading, clicking on things, import model, attempt at texturing, and then rendering. I did get on yutube to see how to do things, and then copied those actions. So really, I don't know it at all. A friend told me about cycles and that I should try it out. Then I saw this thread and I thought I'd give it a go. After reading what was said about blender and normals here, I was curious to see how bad it was. I was pleasantly surprised.
I exported with default Ngon settings in Moi. See image.
Is your blender knowledge good? Can blender display normals? And if so, how does one go about doing this on an imported model? I was also reading about a thing called Bmesh, which apparently handles Ngons. From what I've read it seems it's only from internally generated poly's.
Thanks again for the link.
5083.23 In reply to 5083.22
Blender can display normals. In the properties panel scroll down to mesh display and click on the little cubes under the word Normals: it displays vertexs and faces.
You can turn the imported faces into Ngons select vertices edges or face (X dissolve)
I find the default material that imports into blender with an OBJ is annoying but you can delete it.
I have also found importing a STL into blender is easier to deal with than an OBJ. just because of the material that is assigned to the mesh. It is easy to turn the tri's into quads (ALT-J)
to make normals consistent Ctrl-N
Oh yes, if you use blender 2.49 the OBJ importer imports the Ngons correctly (as seen in moi export preview window).
EDITED: 28 Apr 2012 by VAL2
5083.24 In reply to 5083.23
Hi Val2,
Thanks for that. (ALT-J) certainly cleans the mesh up nicely. I will try STL as well and see what happens.
Thanks for the tip.
Show messages:  1  2-21  22-24
