How to bevel this one.
All  1-4  5-9
5076.5 In reply to 5076.4
Thanks Mike...
LoL. I just added a bevel before adding the little top part. At that moment I thought it was better to first join the little upper part with the rest of the knob and then the bevel.
In your example I see you just bevel first and then joining the little part on the knob....
Anyway, thanks for your time and I'll remake the knob with your workflow.....
Peace,
Rich_Art. ;-)
5076.6 In reply to 5076.1
Hi Rich_Art, one thing that makes this more difficult for filleting is having the front piece here fragmented into 2 different surfaces with this edge separating them:
It would be better in that situation to have just one big front face there instead of it fragmented into 2 front pieces like that.
Then the other thing that could cause you some fillet difficulty here is that you have only a very small amount of space for a fillet to actually fit over here:
Filleting will get confused if you try to ask for a fillet that would entirely eat away that little tiny edge on the back there, so that's going to limit your fillet to quite a small value.
5076.7 In reply to 5076.6
Hi Rich_Art, here I've attached a 3DM file with those front faces combined to just a single surface, it should probably fillet more easily now.
I combined those faces by first deleting them:
Then I extruded the bottom circle upwards far enough to encompass where both those faces were previously:
Then used Edit > Trim to cut the bigger surface with the other piece above and removed this area:
Then Edit > Join can be used to glue the pieces together into a tuned-up solid and just that little bit of cleaner topology will be more friendly for filleting, especially since the 2 previous pieces were not quite 100% identical surfaces, it looked like the bottom piece was an extrusion but the top one was maybe a sweep or came from a slightly different generator curve or something like that.
Hi Rich_Art, so that knob2.3dm that I posted above with the slightly cleaned up topology for the front will now fillet those faces that you were originally asking about better. But you can see here that there's only room for a fillet radius of 0.06 units or so before the fillets would start to collide into each other in that small area:
If you wanted to do bigger than 0.06 then you'd need to do something else other than filleting all those edges at the same time - if you left some of them sharp and only filleted some selective ones that would let you get a bigger fillet on some of them.
5076.9 In reply to 5076.8
That looks cool Michael... I'll check our solution asap..
Thanks for the help (again)
Peace,
Rich_Art. ;-)
Show messages: All  1-4  5-9
