New start....part 2
All  1-6  7-8
5075.7 In reply to 5075.5
Hi Scall,
> When i lofted the peice it did not cap.
That would be because the ends were not planar - MoI only knows how to automatically seal off planar ends of shapes, if the end is warped or bent around in 3D instead of planar it will remain open and you will have to find some other way to seal it off. Usually the easiest way to seal off an end though is to slice it off with some other shape that extends through it by some amount.
> I had to rotate and scale a little to align, however it did work well.
> I wonder if their is an align to a surface tool?
There are some tools for orienting an object onto a planar surface, check out the Transform > Orient tools, some more information here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4487.61
5075.8 In reply to 5075.7
thanks again
Show messages: All  1-6  7-8
