Majik Tutorial: Loop-Ended Handle
 1-2  3-22  23-24
5072.3
dumb question: How do you get the transparent material?
5072.4 In reply to 5072.3
I knew someone was going to ask that!
Beanworks, I simply use PhotoShop to layer two separate screen-shots to create the 'transparent' appearance.
In my opinion, the more and more I use that effect, the more and more I wish there was an option in MoI to apply a transparency attribute to the object or its material.
It's a standard modeling procedure for me to grab objects that obscure my view and then to "Hide" them. The problem is that I often desire to still see the objects by some method for reference.
Michael, I'll consider adding it to the wish list, but a transparent attribute for objects shown the MoI display would prove valuable in applications requiring quick view of technical detail and sub-level illustration. I don't know if it's possible at all using DirectX, but it might be a snazzy feature.
5072.5
ok, I'm glad I haven't overlooked some "transparent" feature in V3. I always use transparency when I work in 3dsMAX or solidworks, and I really really would like so see this feature in MoI. Regardless, MOI is still awesome
5072.6 In reply to 5072.4
Hi Mike, yup transparency in the display has been on the wishlist for quite some time.
It's not particularly easy to add - the way video cards work it's not possible to just set a single attribute and get proper object transparency, the polygons that you want to make transparent need to be sorted from back to front and sent to the video card to be drawn in that back to front order. So it's something that could easily have poor performance unless it is done quite carefully.
5072.7 In reply to 5072.6
I see your point Michael. - Hallowed be your funky wisdom.
Sounds like a smoke maker for many video cards.
The same effect that occurs when I take a MoI file that flowed like glass at 1 degrees mesh setting at work, to then bring it to my home PC to find that the whole thing grinds to a halt at the 15 degrees setting. ;-)
That would have to be VERY optional.
5072.8 In reply to 5072.1
That is really cool.. Thanks. Now I see your colorscheme I need to reinstall it again as well...
Peace,
Rich_Art. ;-)
5072.9
Super cool tutorial.
Thank you so much!
Cool tut!
But what is the use of this object ?
5072.11 In reply to 5072.10
Why Pilou, as the handle to the duster that cleans off your MoI work station!
Ce n'est pas agréable comme le chiffon à poussière ci-dessous:
Ouah! Bless the French. ;-)
But an interesting shape to reproduce, none the less.
EDITED: 7 Jul 2025 by MAJIKMIKE
5072.12 In reply to 5072.11
Oh, you had to go and do it.. The maid.. I suppose I'll visit this tute often, though never end up with a duster handle! :o
5072.13 In reply to 5072.11
Mike, do you still have your scheme somewhere? the one that I have does not works very well with the v3 Beta..
Peace,
Rich_Art. ;-)
Thx for the info!
I had believed that was a new sort of rattle :)
5072.15 In reply to 5072.14
That is a cool object to model of course.. :-)
Peace,
Rich_Art. ;-)
5072.16
Hi Magic! Thanks for a tutorials, as you have made transparent color surface?))))
My love MoI!!!
5072.17 In reply to 5072.1
Hi All
I'm working through this tutorial, but am doing something wrong :( when I boolean Diff the line from the wheel and delete smaller section, I'm still left with a solid wheel, how do I convert a solid into a surface? sorry if this is a basic question :)
Never mind, selected the face and deleted it :(
5072.18 In reply to 5072.17
Stevecim, cutting an object with a curve or line produces new "walls" that are really kind of extruded versions of the cut curve. Drill select into the cut object surface to select that new "wall", then delete it.
Hope this helped.
<< I simply use PhotoShop to layer two separate screen-shots to create the 'transparent' appearance.
So you save 2 images ? (With the use of the Hide function)
1 the first object + Gride
2 the second object - Gride ? and give transparency :)
EDITED: 18 Apr 2012 by PILOU
5072.20 In reply to 5072.13
Hi Rich_Art,
This is my lighting setting. It gives everything a nice 'plastic'-gloss look, and the highlight is a good surface continuity checker.
However, Rich_Art, since the V3 UI mechanism has been re-worked from V2, I'll have to wait to customize it until V3 is finalized.
Michael is using a new system that works with color and gradients to build the UI. You can already go to the right files and tweak those values, but I don't remember where.
You can see some of the UI color tweaks I use inside of this .ini file: http://k4icy.50webs.com/tutorials/moi_ini_EXAMPLE.txt
Hi Michael! Is there any way perhaps to change the map used for the specular highlight in the viewport? A couple of 'mock' florescent lights would be cool.
I have a feeling though, that it is hard-wired into the app.
5072.21 In reply to 5072.20
thanks... :-)
Peace,
Rich_Art. ;-)
5072.22 In reply to 5072.20
Hi Mike,
Sorry, no not at this time - the light map is procedurally generated from the information in the lighting settings. You can adjust the various settings to manipulate it but there is not currently any way set up to just totally replace it with a different static environment map.
Show messages:  1-2  3-22  23-24
