MoI crash when importing IGES?
All  1-2  3-6
5071.3 In reply to 5071.1
Also if the IGES file contains a lot of little tiny slivery pieces in it, it could be possible that the joining process of gluing together all those little pieces is getting confused.
You can disable the join by going to Options > Import/Export > IGES options > "Join surfaces on import".
Does it make any difference if that is disabled?
5071.4
Thanks alot for the quick and good answer Michael!
The problem was the gluing process..
Now all works good! Is it possible to glue the pieces after the import process?
Thanks again!
5071.5 In reply to 5071.4
Hi seasonofchange,
It is possible to do that by selecting surfaces and then using the Edit > Join command. But presumably there is some kind of situation in your geometry (most likely little slivery surface fragments) that the joiner is seeming to have difficulty handling. So there may be some particular area of the model that won't join properly.
You could try using STEP or SAT format instead - those formats transfer already joined solids so MoI does not generally have to figure out how to join a big bunch of surfaces up for those formats.
5071.6 In reply to 5071.5
thanks again!
Show messages: All  1-2  3-6
