Hiya everybody and a little Moi issue to start with.. :)
All  1-4  5-8
507.5 In reply to 507.4
Hi Magnus, I'll be able to check it out better when you send the file, but one other thing you can try is to save it from Rhino as a Rhino V3 file.
MoI uses the Rhino V3 library to read .3dm files - normally V4 files are also readable, but maybe it has something to do with some change in the V4 format for blocks or block definitions or something like that.
I should be able to pinpoint it better with the actual file example...
507.6
Maximus,
...and I recognize you from Maxwell forums, right?
***There is always a better way to do things... Just find your Moment of Inspiration***
507.7
Michael: Yeap as you said 3.0 files might work better, however it was one of the first things i tested and it made no difference. It works just as well as 4.0 files do :) but thanks for the suggestion. Now i shall email the model to you, been a bit busy here this morning but now i finally got time so check your inbox in approx 30 min. :) many thanks in advance.
JTB: Hiya and yeap that's me, Maximus from the Maxwell forum :) nice to see you too here.
/ Magnus
507.8 In reply to 507.7
Hi Magnus, for a quick fix right now use the "Purge" command in Rhino before saving. That should eliminate these extra objects.
The problem is related to blocks. Even though you don't have any block "instances" in that file anymore, there are still the block "definition" objects in there. In Rhion, "Purge" will remove any block definitions that are not currently used by any instances.
Right now there is a bug in MoI where it reads in the block definition objects as if they were regular objects. That's why you are seeing those extra objects inside of MoI.
I have fixed this bug for the next beta (which should be coming really soon, hopefully today), so that MoI will check if an object is marked as a block definition object and will skip over it.
Show messages: All  1-4  5-8
