V3 beta Apr-16-2012 (Windows version) available now
 1-12  13-22
5068.13 In reply to 5068.1
Thanks Michael.
It's funny how you have to add '(Windows version)' these days, It's great to be part of the evolution.
5068.14 In reply to 5068.1
Michael,
Is there a change log somewhere? :-)
Peace,
Rich_Art. ;-)
5068.15 In reply to 5068.14
Hi Rich_Art,
I have one internally that goes over every little change but since that would be so long and kind of technical I usually only mention the major new features, but for this particular release there really aren't any.
5068.16 In reply to 5068.15
Ok no problem but I had a strange behavior tomorrow. I drew some help lines and clicked the object off. After reselecting the object the help lines showed up again.
Never seen this behavior before so I thought it was a new function.
I must admit that I can't reproduce it.... :-( So I must have done something to make this happen. (I'm aware of the script for keeping the help lines life)
Peace,
Rich_Art. ;-)
5068.17 In reply to 5068.16
Hi Rich_Art, hmmm yeah I don't think that there should have been any changes that would affect construction lines.
Is it possible that you've got that "keep construction lines" script set up on a shortcut key and you happened to press that key accidentally that one time?
Please let me know if it happens t you again or if you see any pattern for how it is happening.
5068.18 In reply to 5068.1
Is there a fix to the ringcircle plugin
I recall that from ver 2 to 3 it needed fixing also
No worries I downloaded the ringcircle repaired script posted before and copied in lines 12 through 15
all fixed
Any chance the script copier posted that goes from ver 2 to 3 be updated for ver 3 beta oct to ver3 beta april 2012
thanks
shayne
EDITED: 19 Apr 2012 by SHAYNO
5068.19 In reply to 5068.18
Hi shayne,
Yeah there is an updated ring circle plug-in posted previously, some links here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4933.2
They've never worked for copying from one beta to another beta, they're set up to copy from the release version into the current beta...
All it does is copy files from one \commands folder to the other installation's \commands folder, you can just use windows file explorer to copy the plug-ins you need over, or any file copy utility will do.
So for example a simple way to do it is to just go to your older beta's \commands folder, select all the files there by pushing Ctrl+A, and then do Ctrl+C, then navigate to the new beta's \commands folder and push Ctrl+V inside there - then all the files will be copied over and when it asks if you want to overwrite any just press "No to all" to not do any overwriting - that will do the equivalent of the script copier utility.
I don't really want to mess with creating another separate utility for it since it's actually something that's easy to do just with the regular Windows file management tools...
5068.20 In reply to 5068.19
Thanks Michael
I fixed my ringcircle problem by coping the script lines 12-15 from the posted fix last update
When are you going to stop playing with the Mac version and get back to the important stuff
and finish the ver3, No body cares about mac's anyway :) he he
looking forward to new features , flow is working brilliantly although the button looks empty
ps I would still really like to see a 2 measurement fillet
like the 2 measurement chamfer
cheers
shayne
5068.21 In reply to 5068.20
Hi Shayne,
Unfortunately the geometry library does not have any option to do that, so it's not likely to happen.
Also I'm not really sure how it would really work on things that were meeting up at other than a 90 degree angle, we had some previous discussion on that back here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3628.244
5068.22 In reply to 5068.17
>>Hi Rich_Art, hmmm yeah I don't think that there should have been any changes that would affect construction lines.<<
That is what I thought indeed.. Strange it is. As far as I know I do not have the script installed...
Anyway, when it happens again I'll be back. :-)
Peace,
Rich_Art. ;-)
Show messages:  1-12  13-22
