Sinc Function Curve
Attached is a quick script to create the curve known as the Sinc Function.
See Wikipedia.
The local maxima and minima of the unnormalized sinc function intersect the corresponding cosine function.
What is it good for? :-)
a. Not Much
b. Hats
c. ?
Noticed that a revolve on the x-axis only does one section. Same with sine function.
EDITED: 11 Apr 2012 by BEMFARMER
Size: 111.8 KB, Downloaded: 21 times, Dimensions: 533x388px
5058.2 In reply to 5058.1
Hi Brian, nice hat maker! :)
If the profile intersects the revolve axis, the revolve command cuts the profile by the axis and picks the largest piece to actually revolve.
That's to help avoid making a messy self-intersecting surface result (where the surface crosses through itself) in cases where you might have drawn the profile curve with a little bit sticking past the revolve axis.
5058.3 In reply to 5058.1
Thanks again. Can you make it end tangent to the plane?
5058.4 In reply to 5058.3
Hi Burrman,
Could you please explain what you mean by "end tangent to the plane" ?
Michael, thank you for the explaination.
5058.5 In reply to 5058.4
""""""""""Could you please explain what you mean by "end tangent to the plane" ?""""""""""
Where the ends conclude pointing tangent to the direction. Here is a picture with the start and end points tangent to the direction.
5058.6 In reply to 5058.5
The end tangent to the plane "horizontally" occurs at local minimum values and local maximum values, per
formulas here:
http://calculus.subwiki.org/wiki/Sinc_function#First_derivative
(tan x = -x or tan x = x and x an element of intervals.....)
Need some more study...
