Transparency of View
All  1-2  3-4
505.3 In reply to 505.1
Hi Darktiger - there isn't really a proper wireframe mode right now, but you can select faces and hide them which will leave only the edges of an object displaying.
There also isn't any way to draw transparent objects right now. The regular display kind of gives the illusion of partial transparency because the hidden edges are drawn faintly, but there isn't actually any transparency happening in the surfaces there. You can adjust the degree of transparency of the hidden edges though - that is in the moi.ini file like Pilou mentions (C:\Documents and Settings\[your login name]\Application Data\Moi\moi.ini):
[Hidden lines]
HiddenLineOpacity=34
I do want to add more display options like wireframe mode, etc, but this won't be ready for the V1 version.
505.4 In reply to 505.3
Thanks for the feedback. I will try the ini approach.
Show messages: All  1-2  3-4
