Introduction
 1-3  4-21
5015.4
uhmmm - why is this happening?
hmmm
5015.5 In reply to 5015.4
More info is needed... Looks like a "network" with incorrectly defined curves, or a loft that needs some attention in how it is setup... But it's hard to tell from a screengrab... Can you post the curves and list the command you are attempting to run?
5015.6
I'm using Loft, & no - I have no idea what I'm doing.
5015.7 In reply to 5015.6
Try selecting the blue and running network from this file. You can also do it with loft. The curves would have to be selected properly.
Here are a couple links to past ship hull threads.. Something to pay attention to, is, like in this file, if you refer to the bow after doing network on the blue curves, you will see it is not a very quality surface. In the threads linked to here, Michael discusses building the initial surfaces "Larger and going past those boundries", then trimming them back to the dimensions... This makes for a more well defined surface...
The links talk about some of the pitfalls that others have faced, and provide some solutions...
http://moi3d.com/forum/messages.php?webtag=MOI&msg=3002.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=3052.1
My little video can also gives some ideas and process
(in French but very visual ;)
Script is given on the page : moveslicetopoint
http://moiscript.weebly.com/deacuteplacer-des-objets.html
EDITED: 19 Mar 2012 by PILOU
5015.9
Yeah, I saw those threads but there's some assumed knowledge there that I don't have - I needed to start drawing lines & see what happened. Like this one - http://moi3d.com/forum/index.php?webtag=MOI&msg=3814.1 - I saw that thread & ended up doing a reasonably respectible P51-D canopy.
Do we have any MoI Basics for Idiots tutes that I've missed? Something that works through basic element commands & how they work w/ pick sequences, etc?
Thanks Guys
5015.10 In reply to 5015.9
The help file tutes are suprisingly good at doing that... Under the help button, leads to these:
http://moi3d.com/2.0/docs/tutorials.htm
5015.11 In reply to 5015.10
I would use "network":
5015.12 In reply to 5015.11
then "mirror":
5015.13
I found 'em - thanks
5015.14 In reply to 5015.8
I could've paid more attention to high school French, but that's a slick process for building up a hull. In my case I have no rib or bulkhead sections - just making that part up - & I can see from jtucker's surfaced examples that they need to be tweaked into a more-smoother hull form.
Fun Stuff!
Thanks Guys.
5015.15 In reply to 5015.13
Hi Jed, so actually ship hulls are actually a pretty advanced and difficult shape to tackle, to get a good one is something that will take some time while you experiment with the freeform surface creation toolset - just in general things that are all swoopy and don't have a lot of 2D nature to them tend to require fiddling with a much more advanced area of modeling.
So it's a pretty huge jump in difficulty level from the face plate that you posted at the start here.
5015.16 In reply to 5015.15
That's true, but I'm not completely without experience. It's just a new program that handles differently. Most of the modeling I've done in the past has been wireframe stuff, not for appearances’ sake but for establishing cut paths & the like … & that was awhile ago.
This is pretty impressive software - it’ll dent my Guinness budget but I am planning to buy it.
Thanks again guys, cool forum too.
5015.17 In reply to 5015.16
Hi Jed, that is a nice looking hull that you were able to cook up there, so that's cool!
5015.18 In reply to 5015.16
looks nice indeed. :-)
Just a tip, try to grab your screen with ALT + PRINT SCREEN. :-)
It will only grab the active window and not your whole screen. You can keep things hidden like your taskmanager and current running applications.
Or use this cool script,
http://kyticka.webzdarma.cz/3d/moi/#CaptureScreenToFile
Peace,
Rich_Art. ;-)
5015.19 In reply to 5015.18
Windows 7 has a built-in capture utility. "Snipping Tool"
Just clcik the start button and type Snipping Tool.
5015.20 In reply to 5015.19
Indeed but as far as I can see he uses WinXP. :-)
Peace,
Rich_Art. ;-)
5015.21
Some progress ...
Show messages:  1-3  4-21
