3d Shrink Command (3d Offset)
All  1  2-7
4974.2 In reply to 4974.1
Why do I get premonitions of Death-Star models suddenly becoming popular, after this command is implemented? :)
BTW I also think it would be a nice time saver
4974.3 In reply to 4974.1
Hi NightCabbage - it looks like it is similar enough to Inset that it could be possible to have it actually handled by Inset rather than as a separate command?
It is possible in inset to control the border thickness separately from the inset depth, by checking the "Use separate height" option.
So I think what you would want would be to have a 0 sized thickness for the border but then set "Use separate height" and specify a non-zero height/inset depth type value, is that correct?
Right now I think that it does not think that a zero thickness is a valid value and just bails out, but would that combination of 0 thickness + "Use separate height" height set give you the result you are looking for there?
4974.4 In reply to 4974.1
Hi NightCabbage, also the way you could achieve this right now (if the operations actually don't make bad results...) would be to take your middle section there as its own individual solid slab, and select the top and bottom faces and run Shell on that.
That will build a hollowed out result like this:
And the ring that remains there is the material that you want to have removed, so paste back in the original shape (do a ctrl+c before doing the shell above), so you've got both the original and the shelled one at the same time like this:
You can then select the original one and do boolean difference and select the ring one as the piece to remove.
4974.5
Hey Michael
Thanks for the tip! That looks a bit easier than my current method!
I'd still really love a command for this type of operation though ;)
4974.6 In reply to 4974.3
Hi Michael, about Inset comand.
Moi do not allow to set thikness to zero in "Use separate height" mode.
4974.7 In reply to 4974.6
Hi mir4ea, the Inset command is basically set up to generate a shape that has a border around it - if you want something with a 0 border width that would then be just a regular offset, use Offset or Shell for doing something like that rather than Inset.
Some previous discussion here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5508.11
Show messages: All  1  2-7
