is the a way to draw permanent construction line? ( until I want to delete them :) )
All  1-5  6-7
you can also use any curves with a special colors that you can hide at any time!
EDITED: 23 Feb 2012 by PILOU
4957.7 In reply to 4957.5
Hi Steve,
> what I was thinking with the circle, was this, from ArrayGem,
> "The center of the base circle will become the point that is
> placed on to the surface" i.e the centre of the circle will be
> placed on the target point.
Yeah I think that CopyToPoints should do what you need - in the first step of that command you pick the base point for what spot on the object you want to have located on the target point, like the Transform > Copy command.
But then instead of clicking new points with the mouse for where to copy the object to, the CopyToPoints plug-in lets you select point objects and then uses those for the target locations.
Show messages: All  1-5  6-7
