is the a way to draw permanent construction line? ( until I want to delete them :) )
All  1-2  3-7
4957.3 In reply to 4957.2
thanks, I'll take a look.
4957.4 In reply to 4957.1
Hi Steve,
It's possible to make one that will persist through the same modeling session (not through file loading though) instead of disappearing at the end of a command like they regularly do.
See here for some scripts like "Keep construction line" that you can set up on a shortcut key:
http://kyticka.webzdarma.cz/3d/moi/#KeepCLine
Also a plug-in command that lets you set up persistent construction lines here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=1029.1
> I want to place X number of objects to a bunch of points,
> still using a circle around the object to control depth, like
> ArrayGems.
I don't really follow how the circle spacing comes into effect for placing objects on to points, but for replicating an object to points see the CopyToPoints plugin here:
http://kyticka.webzdarma.cz/3d/moi/#CopyToPoints
4957.5 In reply to 4957.4
Thanks Michael, I think that script does what I need, what I was thinking with the circle, was this, from ArrayGem,
"The center of the base circle will become the point that is placed on to the surface" i.e the centre of the circle will be placed on the target point.
Cheers, Steve
you can also use any curves with a special colors that you can hide at any time!
EDITED: 23 Feb 2012 by PILOU
4957.7 In reply to 4957.5
Hi Steve,
Yeah I think that CopyToPoints should do what you need - in the first step of that command you pick the base point for what spot on the object you want to have located on the target point, like the Transform > Copy command.
But then instead of clicking new points with the mouse for where to copy the object to, the CopyToPoints plug-in lets you select point objects and then uses those for the target locations.
Show messages: All  1-2  3-7
