File size limit
All  1-7  8-9
4942.8 In reply to 4942.4
Hi Sebastian,
> UPDATE: Set the value to 5 (was 0.2) and unchecked
> inflections and its worked!!
Yeah 0.2 is extremely tight - that's asking for only a deviation of 0.2 angular degrees between surface normals of the display mesh, so that's going to generate a tremendous number of triangles.
Even 5 degrees is still quite tight - the default is 10 and even that is on the tighter side.
If you are working with large files I would recommend setting "Mesh angle" to 25 degrees (25, not 2.5) and uncheck "Add detail to inflections" and that will help lessen the memory load by quite a bit.
4942.9 In reply to 4942.8
Thanks for the replies, everyone. Like I said, I got it sorted and learned something too :)
Show messages: All  1-7  8-9
