is this something I need to worry about?
4941.1
Hi All
I've seeing strange results in the export to STL preview, not sure if it's a real problem for just a break up in graphics, using OSX beta.
Notice the 3 leaves on the left are not showing triangles? , the left side was made by mirroring the right side. I delete the whole left side, re-mirrored it same results.
here is how it looks in meshlabs
Cheers, Steve
EDITED: 18 Feb 2012 by STEVECIM
Size: 153 KB, Downloaded: 48 times, Dimensions: 1061x828px
4941.2 In reply to 4941.1
Hi steve, there is something wrong with those ones - if you zoom in really close to their tip you can see that it's kind of messy there:
That thing that looks like a tiny squished flat edge actually appears to be a slivery thin tiny additional surface, and a degenerate face like that will interfere with calculation of the outward facing surface normals. So probably that little tiny face will need to be removed and the points of the large one squished down to a single point to make that into a proper solid without any degenerate things in it.
4941.3 In reply to 4941.2
Thanks michael, I just merged off the ends, left me with a flat end, thats less than 0.01 mm :) cleaned up a few other places has well :)
4941.4
Hi Steve
I am interested how you made the leaf shape pieces that were the problem
they appear revolved but I have problems making them
cheers
shayne
4941.5 In reply to 4941.4
Hi shayne, maybe doing a revolve and then using Flow could be a good method, check out here for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5316.6
4941.6 In reply to 4941.5
Thanks Michael
Perfect , its friday, brain is on hold , had a play easy as pie
I need to practice using flow more :)
Have a great weekend
shayne
4941.7 In reply to 4941.4
Hi Shayne
I think the revolve and flow, would be an easier method, I think I used sweep with 2 rails and had a few problems ;) ( when I get a chance I'll pull up the old files and have a look at what method I used :) )
Cheers, steve
