Pop up error pressing R for ring size
4933.1
Good evening Michael, I just downloaded Ver3 beta, when I try to use the ring size feature , I get the error message and when I close that out the ring size window pops up, it is slightly different from Ver2 in that all forms of ring sizes pups up at the same time. I understand that this is beta, but is there a way I can eliminate all the other ring sizes and just keep US?
Best regards
Tom Kimbrough
Size: 35.6 KB, Downloaded: 43 times, Dimensions: 470x266px
Size: 16.4 KB, Downloaded: 25 times, Dimensions: 208x271px
4933.2 In reply to 4933.1
Hi Tom, please see here for updated RingCircle script files that will then work ok with V3:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4441.9
http://moi3d.com/forum/index.php?webtag=MOI&msg=4441.11
There are a couple of different versions of it out there - if you could maybe post the one that you are currently using (it will be 2 files, a .js and a .htm file in your commands folder) I could modify it to only show US sizes for you, it just involves removing a section of UI.
4933.3 In reply to 4933.2
Thank you Michael, I will post tomorrow after I get home from the shop. I am just returning to work after spine surgery Jan 2011 so I got a lot of catching up to do. Thanks for all your help.
Best regards
Tom
4933.4 In reply to 4933.3
Hi Tom - wow spine surgery is a tough one, hope your recovery goes well.
